was hearing and following up on projectors months ago.. was interested in the Epson ls? laser..
Total newbie here.. so need help.. here are the specs .. looking for projector for around 5k
thank you for your input.. here is additional information
room is 24 deep and 17 wide
ceilings is 10 feet high.
back of room will have row of four theater chairs at distance of 20 feet- these can be on riser.. but projector above chairs.
so projector will be about 22 feet from screen at farthest point .. can move closer if need be .
in front of those at about 16 feet couches, or additional chairs ushaped couch so parts may be a little closer
basement can be blacked out.. but might have some light occasionally as rest of basement has pool table ect on other end.
would like to have 4k upscaling.. is this worth it?
primary viewing most likely on couch that is about 16 feet away.
room is light controlled only two window wells to contend with .. blinds no issue.
Very limited 3D
viewing. most likely not a factor at all. but I want to be sure the screen works with 3D.. but 4k upscaling.
what is largest screen I can get. screen recommendations 16:9 or otherwise?
would be watching movies in darkenss. television most likely in ambient light.
was thinking of doing a automatic drop down screen with tv screen behind for when we have more action going on in basement.
no beams in the path such as ducts ect.
sound is open to debate .. start off with standalone and maybe move up from there.
thank you in advance.
Very limited 3D
