I've been frothing at the mouth for a projector the last 4 months or so, and now that I'm back out of debt from a europe trip I'm looking to get one sometime between now and 2 months from now. I was basically set on getting a sp 4805, but I really am not sure what would be good for my setup...
I'll be sitting about 11 feet from the screen, room is 13X10. There's two largish windows on the side of the room, but I was planning on some fabric or another that I can use for blinds to eliminate what I can from the light from the windows. I'm not stuck on one screen size or another, basically what will work the best. Obviously I'd prefer a larger screen size, but the room size probably won't allow that with a smaller res projector if that's all that's in my price range.
Mainly this will be an equal composition of being used for movies and gaming, along with probably some regular and hdtv viewing. Seeing how the xbox 360's coming out with all games at 720, that was on thing that had me wondering on the sp 4805.
So I now know of sp 4805, z2, or sharp dt300 that seem to be some things that would work. I really have no clue what I should really get for my set up though. I'd prefer cheaper options, as you can see from the 3 I listed above, but I could go up to 1500 if necessary, but obviously under 1000 is a good thing ;o)
Thanks if you can help!
AMM
AMM
