Status
Not open for further replies.
1 - 15 of 15 Posts
Hi everyone. I am new to these forums, and to the world of HDTVs. I have a $750 gift certificate to Sears, and I need to pick a TV. I don't want to spend much. I have never owned an HDTV before, and the most I will spend is $450 on top of the $750.
Here are the ones I am interested in:
http://www.sears.com/sr/javasr/produ...00&tab=spe#tab
Samsung Pros:
Built in HDTV tuner. Sleek design. Thin. 720P
Samsung Cons:
I have heard it has some PQ issues
Sony Pros:
2'' bigger than samsung for same price
Sony Cons:
4:3 contrast Ratio. No 720P
Toshiba Pros:
34 inches. Picture in Picture. 720P
Toshiba Cons:
$200 more. I have heard it is built by some Chinese company.
This is all the info I have gathered by just surfing the internet for an hour or two. I don't know if it is accurate or not though. The important things to me are picture quality and playing xbox/xbox 360 on it. I can't spend any more money than what the Toshiba costs, and it must be from Sears since I have a $750 Gift Card. Thank you guys for any help, and hopefully this can help make the search for the right HDTV a bit easier.
Banned
none of these TVs display 720p
all of them will take 720p input
what about the Sony KV34HS420?
I would avoid the Slimfits and the Toshibas
also Sony sells the KD32XS955 and KD30XS955 and KV30HS420 all which are in your price range
the KD TVs come with a ATSC/QAM high Def tuner with cable card slot and the KD30 is a super fine pitch TV
the Sonys will be hard to beat if image quality is a big concern
the Slimfit TVs are known for poor geometry and Toshiba should be consider overpriced (as they do not make them any more)
Banned
huh what CRT based HDTV does not do 480i/p ?
the KV34HS420 supports 480i and 480p input and displays 480p, 960i and 1080i
most CRTs will only display 480i as 480p or maybe 540p
the Sony has the option to choose 480p or 960i for 480i inputs
you really should go to the manufactures website rather than Sears which has alot of incorrect info
like the 720p info as well
by the way, no CRT TV will display 720p, they take it as input and scale it to 1080i or 540p as in the case of the Toshiba
read the reviews of the Slimfit TVs here
most report the image quality is rather lacking in comparsion to regular CRTs as well as geometry distortions
Discussion Starter · #5 ·
I will look at the Sony, but the problem with the Sony for me is the price. I found out that the samsung is on sale at Circuit City for $899.99. After PM and 10% off of the difference at Sears, the TV is $889.99 making it $610 less than the Sony. That is a huge difference in price, and I am not sure if it is worth it.
Banned
Originally Posted by spin03
Toshiba Pros:
Toshiba Cons:
The Toshibas are built by a Thai company called Orion Electric. 85% of the Toshiba tube TV models are Made in Thailand. How many times do I have to say this to correct people?
It seems like you already made up your mind with the Samsung.. I doubt anyone will change your mind or convince you otherwise.. The slimfit has problems.. Geomtry problems.. Horizontal res on the Samsung is 800 lines of res.. The Sony model has 1,400 lines of horizontal res.. It's pretty safe to say that its worth the extra cash..
was talking about the 30inch XBR955 model..
Premium Member
I would not buy a Samsung. Too many problems.
I would only buy a JVC, Panasonic, or Sony tube TV. In that order.
Banned
I understand that Sony is out of your price range, but the Sony reliabilty is pretty good by what Consumer Reports say. Samsung's reliablity isn't too great. I think the Toshiba 34HF85 is more reliable than Samsung. There are no problems reported in the 34HF85 so far. It may be a safe purchase.
Banned
I take it back. One person here is having a problem with the component input in the Toshiba 34HF85 right now. There are very very few 34HF85 owners so far, so reliability will be unknown for right now.
Banned
I take it back. One person here is having a problem with the component input in the Toshiba 34HF85 right now. There are only a few 34HF85 owners so far, so reliability will now be unknown for right now.
Banned
I would never get a first generation slimfit tv set, i would wait untill they work the kinks out to get one.The technology sounds promising if they can match the PQ of a regular tube set.
But then again, why wait for the slimfit technology when ther is a technology called SED that has the same PQ as a crt and as slim as a plasma for almost half as much as a plasma costs!
That's what i'm waiting for, these SED sets, also they will do 1080p native so that's awesome!!! Can't wait...
1 - 15 of 15 Posts
Status
