Status
Not open for further replies.
1 - 4 of 4 Posts
Hello all,
I have a 106" high power screen, and my AE100 is ceiling mounted. The blacks on this pj were already bad & now on the white screen, there way too bad. I need a new PJ. I sit 11' from the screen. I also need a short throw pj which puts HS10 out of the picture. I considered TW100, but it is out of my budget. I'm thinking 300u or Z1. I will be using component from RP-62, no HD...yet. Which one fits my situation? BTW, i know,...i sit too close. :)
Thanks in advance.
Well, if you want better blacks you can rule the HS10 out right away :). You can choose the HS10 for a lot of valid reasons but better blacks should not be one of them. Either of the 300u or Z1 will give you better blacks.
Hmmmmm........ whats your budget?
I hear the upcoming "Goo" projector is supposedly a KILLER. Be watching for that. And if you got a REALLY good budjet, why not look at the Dwin TV3.
Discussion Starter · #4 ·
Budget is about $2k to $2.5k. What the heck is a goo pj?
1 - 4 of 4 Posts
Status
