So you're looking for a receiver and 5.1 speaker system for a max of $800?
Well, in that price range you're looking mostly at HTIB systems, which just about universally suck.
Personally I would check out ebay and audiogon and find a good used receiver for as cheap as you can get it.
Then get a 5.1 speaker system from www.fluance.com They're pretty darn good for the price.
*edit* Actually my math was off. If you buy a 5.1 system from fluance you'll have enough money left to get a decent receiver that should do what you need.
