1 - 2 of 2 Posts
I got a Harmon Kardon AVR254, Energy Take 5.0 speakers and this sub. I connected everything as I wanted and then ran the auto ezsetup thingie with the mic. After the testing, it set my sub mode to off, front crossover levels to "Large". This being my first sub, I have no idea what the stuff on the back mean. In the vk-12's manual it says if u use sub in, I need to set receiver type to pro logic, or crossover frequence cannot be set. I tried watching a movie, and there was nothing coming out of the woofer.On the woofer, i put the volume at "2", phase 0, and crosoover at 100hz.
set sub to ON, fronts to small turn up sub gain to halfway..should have some sound then.
Use the LFE out on the receiver.
1 - 2 of 2 Posts
