Help me SOFA shop? :)
893 Views 7 Replies 5 Participants Last post by  Shift
Just sold my theater chairs.
Wife and I are wanting to find a good straight sofa that will fit 4 persons/people on it.
Is there anything out there that would fit my sofa shopping description?
I would like it to recline, but I can bare w/o that option.
I perfer leather and probably black in color. Help, help :) ?
Thanks all for any suggestions :)
Status
Not open for further replies.
1 - 8 of 8 Posts
We have a 3-seat reclining sofa from Arizona Leather and we're very pleased with it. Very comfortable. Many of their styles are available as 4-seaters.
http://www.arizonaleather.com/styleG...er.asp?cate=10
Good luck!
Mark
nice sofas, but they are located only in AZ :(
We have the Berklin's in that set up. It looks like a sofa 4 recliners stuck together with arms on each end it has the power option and butt kickers installed, got it from slumberland in mn.
Hey can I see a pic? I mean if you can share, so that way I can see how that looks? Thanks!!
Shift:
Not sure what your budget is but I can tell you from my own research that Fortress makes sofas with retractable arms. Arms up, you have a sofa. Arms down you have individual seats each with their own recline controls and cup holders...I also think a good alternative might be found at LazyBoy for less.
Let us know what you find.
Good luck.
BP
See less See more
Shift,
Have you checked JCpenney's. I found this and it if you put two together it might work
http://a602.g.akamai.net/7/602/175/2...b80e76204R.jpg
Victor
Thanks all.
I was actually at Furniture Row and decided to get something like this:
http://www.ashleyfurniture.com/Graph.../5000967_G.jpg
* Should be here in about a week. very comfortable from the demo we sat on
1 - 8 of 8 Posts
Status
