1 - 8 of 8 Posts
I want to build a mITX HTPC for my bedroom..
It must play h.264, VC1 and MPEG2 at 1080p24 flawlessly over HDMI using LPCM 7.1 sound. Idealy SD content should good.
What are your suggestions?
Case, CPU, Memory, MB
Premium Member
Wait for ZOTAC GeForce 9300-ITX WiFi .
A list of other components is here .
Discussion Starter · #3 ·
Whats the ETA on this board? Also, the 9300 requires a minimum of a 300 watt ps.. most mITX cases have 250.. Thanks for the link..
You can turn the power supply around so that the label is next to the case. Then the motherboard won't see that it's 250W and will be tricked into working.
Discussion Starter · #5 ·
I didnt think of that... I will give that a try!
Premium Member
I think ETA is unknown yet.
That's totally untrue. Check this post . It's extremely hard for the system I mentioned to consume more than 100W.
Premium Member
I would choose pico-ITX (100x72mm) for Ion.
1 - 8 of 8 Posts
