Status
Not open for further replies.
1 - 1 of 1 Posts
I want to upgrade my HT system. I currently have B&W matrix 803's for the front and a B&W htm matrix center, boston acoustic towers for rears. I have a budget of 1500 andd use the system primarily for HT. I need a tuner to keep my wife happy. I dont mind used equipment. Here are some things i have thought of:
Rotel receiver- 1055
Yamaha 1400/2400 or pioneer 53txi or denon 2803/3803 as a pre/pro with a used $600-700 amp. On Audiogon there are parasounds, adcoms, B&k's and anthems in that price range
Outlaw 950/ 7100 combo
While I understand the changes in the processing end of the equation, have there been significant changes in the amps also or are amps from 1999-2001 from good companies fine to use. In terms of used amps any suggestions?
Thanks for your help
1 - 1 of 1 Posts
Status
