Emotiva T1+ C2+ B1+ for ~$1k, and put the rest towards subwoofers if you don't have them anymore.
Then just use the B1+ for your front mains instead of the previously suggested T1+ and downsize from the C2+ to the C1+ if you need to.Trying to get away from towers/floor standing speakers to save space.
Right now i have bp9080x's ,cs9060, and a pair of sr9080's.
What are some good options for replacement speakers that take up considerably less space, sound great, and fit inside a budget of say.... 2k for lcr and rear surrounds?
To answer some questions.. I have 2 SVS PB3000's that I'll be keeping. The SR9080s are great but id like to have matching speakers. Im looking for 5 total speakers, LCR and RS's. I think id like to be able to wall mount the FL and FR speakers along with the rear surrounds. Center will go under tv on a stand. I do really like the sound I get from the def techs. The room is used 90% movies, the other 10% music, tv, gaming.
No WAF needed and wall mounting FL/FR, 90% movies = I'd take a gander at the Ascend 200SE in that case. Sealed design, dual 4" woofers in an enclosure just a little bigger than most single 4" woofer bookshelves.Also. WAF has no input on what i do in that room. Running everything with a denon x4500h at the moment.
? KEF tends to be narrower.Most Def Tech owners really enjoyed the large soundstage so KEF with their concentric drivers would be a nice move for those looking for more refinement while retaining wide dispersion.
If wall-mounting is a strong desire, and I understand that in a small room, then:To answer some questions.. I have 2 SVS PB3000's that I'll be keeping. The SR9080s are great but id like to have matching speakers. Im looking for 5 total speakers, LCR and RS's. I think id like to be able to wall mount the FL and FR speakers along with the rear surrounds. Center will go under tv on a stand. I do really like the sound I get from the def techs. The room is used 90% movies, the other 10% music, tv, gaming.
Then the B1+ x 4 all and C2+ (or C1+ if you are trying to save space).Trying to get away from towers/floor standing speakers to save space.
That is how I am setup now. My couch is 30 inches off the back wall and im right about 8ft to the screen. "screen is an 82" Q80" And you're right.... if i move a foot forward, or backwards the bass vanishes. I have the subs back to back between the couch and wall.If you do on-walls like this, pull the couch forward 3-4 feet. Situate it at about the 8-9-foot mark from the front wall. You will get MUCH better sound and bass there. Wall-mounting the fronts gives you the room to get that couch away from the back wall.
You might get even better bass if one of the subs is moved up front, taking advantage of the front/back placement.That is how I am setup now. My couch is 30 inches off the back wall and im right about 8ft to the screen. "screen is an 82" Q80" And you're right.... if i move a foot forward, or backwards the bass vanishes. I have the subs back to back between the couch and wall.
