1 - 2 of 2 Posts
What is the correct way to wire my Sub. F113 via a JBL WEM1 wireless adapter.
Do I do RCA to Y RCA into the RCA inputs.
On the receiver side, I so the same and just Y out back the L/R on the input of my JL F113.
Or since sub is *mono*, it doesn't really matter if I plug into both channels and just use 1 ?
Do it the same way as you would if you were using a cable. The respective owner's manuals will tell you how to do that.
1 - 2 of 2 Posts
