I've searched all over the place trying to gather some information and I think I confused myself even more about the resampling and the whole issue about bypassing it with asio or kernel.
Right now, I am using asio and kernel plugin with winamp with revo7.1 and I absolutely love the sound output. If I understand correctly, by doing this, it prevents the sound from resampling to 48 but instead to 44.1, right? I've recently installed asio4all, and now all the sound coming out of my computer using spdif is 44.1 as according to my receiver. Is this normal?
If it is, what is the difference between, let's say, using windows media player vs. winamp if they all output to 44.1? Are they in same quality or is one better than the other? Correct me if I am wrong, but I thought that you can't use asio with wmp10.
Just to clarify, I am planning to use MCE2005 with my htpc and if I understand correctly, the default player is wmp10? If so, is there a reason why I can't ditch the entire winamp setup and use wmp10 with asio4all to achieve same sound quality with simplicity of MCE2005?
Please help!
Please help!
