i'm having some trouble with the setup of my panasonic rp-91.
first off, i have a slight shift to the right with 4:3 material viewed in progressive mode. How can i correct this?
also, this player supposedly saves picture settings for up to 200 discs. I have been playing around with the user settings on a lot of nonanamorphic discs that don't automatically scale....but with a lot of them i'll put them back in and they won't have the settings saved, plus a lot of the settings seem to be leaking over into my properly flagged anamorphic discs. what am i doing wrong?
to add to the confusion, with 16:9 movies in "N" (normal) mode, sometimes the player is setting itself to +1 shifted position, sometimes it's not, and i can't change it back to "0" when it is.
with 16:9 material that i watch in "normal" mode, is the player "saving " the preferences even though i haven't changed anything?
i'm also curious if anyone ever uses the noise reduction on 16:9 material.
thanks
thanks
