1 - 1 of 1 Posts
Hello!!!
I have purchased Freecom NETWORK MEDIAPLAYER 35 Drive IN kit. all was ok until today. i connected the mediaplayer with my pc and something happened.
The mediaplayer is not working. Only HDD led is lit. when i connect the mediaplayer to the pc usb port then the blue backlit on the front panel will flash as usually but computer does not recognize the hdd. when i remove the hdd then the mediaplayer will not switch on the power and any led will not lit on. so by the way- are there any other ways to get my mediaplayer back to work before i try to recover the jtag? the mediaplayer does not have any jumpers to reset the system?
1 - 1 of 1 Posts
