I believe a cheap optical cable with a toslink adapter on the end that plugs to the monster cable (looks like a headphone jack) is all you need. It wouldn't hurt to try.
Update:
The monster adapter is shorter than a toslink adapter, so it is proprietary. As a poster said below the XBOX 1 version works fine and is being clearanced.
Originally Posted by dacornholio hi there i just purchased the X400 monster cable for xBOX, and now i want digital audio for it as well. can someone tell me is getting the lightwave X100 cable the ONLY way i can get optical out from my xbox? J |
Update:
