Status
Not open for further replies.
1 - 7 of 7 Posts
I have a Barcographics 808 and was adjusting the convergence when a error message came up (not smart enough to write it down) and then the picture just left. Now it will come out of standby and power up but no video. Everything else seems to be working alright. Any suggestions would be greatly appreciated. I live a long ways from any dealer and a 747 would have to be rented to get it to one. Thanks
Mark
:confused:
What does it say on the screen when you select the input you are connected to??
Terry
Discussion Starter · #3 ·
Nothing comes up on the screen. Tubes light up and when video is placed online the barcos internal area makes a differnet sound however no picture comes out.
Are you selecting the input for the source material you have coming into the projector. #3 or #5 depending??
What do you mean the "tubes light up? Describe.
Terry
Try only hooking a video source up to the normal video input and press '1' on the keypad. See if the video pix comes up.
Sounds like your HV and sweep is normal; that is a good thing!
Under the cover on the right side as looking floor mounted and from teh back, there is a PC board with a bunch of green LED's and one red one on it. Which ones of those are on or off?
Curt
Curt
1 - 7 of 7 Posts
Status
