This weekend when I turned on my 10 year old Sony receiver it started to smoke. I quickly had it completely unhooked and ready for the trash. When I unhooked everything my Energy S8 (I think that's the model, the sub that came with the Take 5 system) sub started a loud hum. I unplugged it figuring something was messed up with where the wires ended up.
Anyway, I picked up the cheap Onkyo 504 receiver from CC and hooked everything up yesterday. All sounds fantastic, only problem is when I turn off the receiver my sub starts that loud hum.
I checked the wires and can't see anything wrong. However let me describe how I've had this setup.
I have some in-wall speaker wire that goes from the back of my room to the front. I took a decent quality cable with RCA ends and cut it in half, stripped the wires and twisted them onto the ends of the in-wall wire and taped them up making sure none of the metal from the wires touched. There were some strands of wire in the cable that were not shielded that I figured were there to give some more structure and make the cable stronger that I did not connect to anything. There were 2 insulated wires in the RCA cable, one red and one black. So now I've effectively got a long cable with RCA ends so I can plug one into my sub and another into the receiver.
I've tried everything I can think of (verifying everything is plugged in tightly and verifying the twisted wires aren't touching and the electric tape is in good shape. But the only way I can make the sub stop humming loudly is to either turn on the receiver or unplug it, that's not a good solution.
Can anyone help give me some ideas?
