1 - 7 of 7 Posts
My month old Mitsu 73835 TV remote died & I have a time lock set.
I have an installer coming for my surround sound system in 3 hours & I can't
turn on my TV.......any ideas???
The info manual says to hold the menu button down for 8 secs & it will unlock the front panel controls, but it does nothing about the time lock.
HELP!!
- Cam
Not sure what time lock is as my set does not have this feature but did you try new batteries? I guess as a last resort you can always try the system reset button on the tv but you will lose any settings you might have.
Discussion Starter · #3 ·
The system reset does not bypass the time lock.
I had been having trouble with it for several days, but since I mostly use the cable box remote, it was no big deal, all I used the factory remote for was to input the time lock code.
The set has the capability to have the TV "not" turn on during certain hours. I had this feature turned on so that this TV was not used ALL day long by people in the house (several others to choose from & I was trying to save the lamp, lol).
The cable remote WONT input the lock code, it has to be done with the factory one.
I am getting a Universal Remote (brand) universal remote....my installer says he thinks that he can program it to input the code (fingers crossed).
As a last resort, I was thinking I could go to Best Buy if need be & hope they would let me borrow a remote from a display unit.
Yes, I tried three different sets of batteries.....
Discussion Starter · #4 ·
The new remote allowed me to unlock my TV & the install went great..
Have you tried to reset the remote?
Remove the batteries..
Push each button on the remote (start at the Top)
Repeat 3 times
Replace the batteries..
Discussion Starter · #6 ·
Repeat 3 times
I had called Mitsu on Friday & that is what they said to do....remove the batteries & push each button twice, then replace the batteries.
I did this twice, & they are sending me a new remote under warranty.
As posted above my new Universal Remote allowed me to input the code.
1 - 7 of 7 Posts
