Status
Not open for further replies.
1 - 1 of 1 Posts
I've installed the latest 1.62 driver and application with MDP120. I find that there is a horizontal line at 2-3inch below the top of the screen when MyHD is set to 1080i or 720P RGB/DVI. There is no problem for 1027x768.
I'm sure it is not the problem from the projector. The same situation appears at LT150 and TW100. Moreover, the line also appears at the overlay window within the desktop.
I've removed the card and uninstall the driver and software, and then reinstall every thing but the line is still there. It seems to be a hardware problem rather software one.
Any suggestion?
1 - 1 of 1 Posts
Status
