1: Look into the lenses with a flashlight and look for discoloration, such as a darker area. Some wear is common, but you should NOT see any discernable writing, logos, or a windows desktop image with the set off.
2: In the set-up menu is an hour meter. However this can be reset, and may be useless.
3: Yes, and no. A line doubler is the minimum I'd use it with, but a DVDO Iscan is a better unit for the money, and best would be a HTPC. Video only looks bad on such a high resolution unit. The IDC-3000 works, but it's really not that good. You may not have a quad decoder card in the PJ, it is an option. This means you need to use RGBHV inputs, as you really should.
4: Hard to say.... depends entirely on the tube condition. Mounts go for $100 to $250, IDC-3000? Not sure. The IDC-2000 would be a better unit.
Make sure you get the set up remote! You CAN use a Pronto, but the original remote makes it simpler.
Marc
Marc
