Status
Not open for further replies.
1 - 2 of 2 Posts
· Registered
I have recently installed a NECXG1352 Projector. Yesterday it shut off without warning. It will fire back up but will shut off after 10-15 seconds. The indicator on the back of the screen says Fd
Any suggestions? The power to the machine is good and I have surge protectors on the system. Fans are working inside. Thanks for any help. Chet
· Registered
If it was working before you installed it I would open it up and check all the plugs or connections, look for anything that might be rolling around inside like a screw, nut or washer that might be shorting something out. I would check to see that you have a good 120 VAC source, wiggle the plug to see if it is intermitent, check the polarity, the voltage. I would check anything that has changed sense you installed it.
Good luck Deron.
1 - 2 of 2 Posts
Status
