1 - 6 of 6 Posts
· Registered
I am at BB now and in the Magnolia center! they have 1 Denon 1908 left on clearance for $299! I originally came for the 1909 but I really DO NOT need the upconversion or the lossless audio (I have a PS3 I am using for Bluray) are there any other major differences between the [email protected]? i would LOOOOVE to say $300 if I can... Please tell me this is a good buy! Thanks in advance
· Registered
you can get it cheaper on line( by a few bucks)....but its not a bad deal if it does all you want. the difference is the 1 hdmi input and a major revamp of the audessey calibration system.
· Registered
Discussion Starter · #4 ·
I dont need Upcoversion... I dont care about a 3rd HDMI input...
Is the New audyssy EQ and dynamic volume worth $300? Will this still sound good? Please I have tried the sony DG720 and it was very weak sounding.. is this better?
· Registered
not worth 300....and certanly not woth double the price grab that thing before someone else does.
1 - 6 of 6 Posts
