Status
Not open for further replies.
1 - 1 of 1 Posts
I just bought a Toshiba 34HDX82 television and have it hooked to a Denon home theater in a box. I'm really not sure what the difference in picture quality is between an interlaced and a progressive scan dvd player. My question is should I invest in a progressive scan dvd player, or just use the one built into the Denon? The picture I get from The Denon seems great, just wondering if it would be better with the progressive? Thanks
1 - 1 of 1 Posts
Status
