Well, my Wega finally died, so I am aiming for a plasma. [ this week]
Here is the dilemma, I am considering a] a 46 inch panasonic tcp4632c, 720 resolution,
or b] a panasonic tcp46s30 1080p resolution.
The 720 is local, and is less expensive [ could return it easier if I had to, I THINK]
The 1080 is something I would have to order online.
I have dish HD and from all the reading I've been doing today, Dish only broadcasts 1 true 1080 channel.
Some are not Hd, others that are HD, well, I understand are HD lite. [ what is the point then of 1080p?]
I was told I would have to sit twice as far away [ ?] with the 720
Is the resolution that much better on 1080p even tho the broadcasts are not true HD?
What about text [ subtitled movies, closed captioned, etc.] better on one than the other?
Anyone have either of these models? If so are you satisfied with PQ?
I will take all the advice I can get, even tho I am starting to feel overwhelmed, and no smarter than before I started my due diligence.
Thanks to all who take the time to reply!
I've been reading these forums for weeks,
