I've run into my first problem with my Hitachi 5500. I want to take advantage of the two RBG inputs. I have been running my Dish 6000 and AccessDTV at 1080i, component. I've tried hooking both to the 5500 RGB ports and specifying 1080i, RGB. In both cases, a 4:3 image which should have the vertical black bars on the sides is stretched out to fill the 16:9 screen. The bars are there as they should be fine in component mode. I can also overcome the problem by setting the 6000 and the AccessDTV to 720p, RGB, but I'd rather not do that.
Any ideas?
Chuck Davis
Any ideas?
Chuck Davis
