1 - 1 of 1 Posts
trying to create a DivX out of a portion of an MMS stream
1. MMS stream was dumped to a file (RAW) in VLC (version 0.8.6)
2. Dr DivX (version 2.0.1 beta) can not open this RAW file (plus Dr DivX doesn't do portion-only processing, right? It would reencode an entire file, which I don't need)
3 VLC opens the RAW file just fine, but I cannot extract a portion of it (I guess because it treats this RAW file just like a stream, so it doesn't know its length, etc)
4. I need to re-encode it with VLC
5. Extract portion of the re-encoded file with VLC
6. re-encode output of step 5 with Dr. DivX.
My main question is on step 4. VLC gives you a bunch of Video and Audio codecs to choose from (to re-encode). What combination should I pick? Also, I assume reencoding options in step 5 should match those in step 4, right?
Also is there an easier way to achieve what I am trying to achieve (with freeware/shareware only)?
Any other help/suggestions?
thanks in advance
1 - 1 of 1 Posts
