Try the WM Stream Editor, I will try it later tonight. Plesase reply if you are successful, I would like to get that working too.
I wanted to test out the new MP4 decoding ability but all the MP4's I create dont work. I ge some kind of error after I put it on a USB flash drive and try to play it. Your approach may work better, MUX the components into a WMV instead of an MP4. Then I could stream it over the network too! Great idea.
-Nate
-Nate
