1 - 2 of 2 Posts
· Registered
Hi,
I have finally made my mind to go for a projector. I have a decent size rec room. I will be mounting the projector on ceiling. My budget is around $1500.
Do also let me know is it a good time to buy or I should wait a month or a 2 more for a better product in my budget.
I have Denon 1910 AVR and definitive speakers. So only remaining thing in the puzzle is Projector. The main use will be for movies and games(PS3). Thanks.
Dev
· Registered
Your budget is great! You can get a nice 1080p projector for that. Tiger Direct has the Infocus X10 for about $1100 or $1200. go to projectorcentral.com for comparisons and reviews as well as reading up here, which is the best resource. Anc contact the AVS store (not sure if it's called that), they make good deals, and really deserve our business.
1 - 2 of 2 Posts
