better to use throw distance calculator from projector central website
Right. But both calculators will still recommend me where to mount the projector. My original questions still unanswered though regardless which calculator I use.better to use throw distance calculator from projector central website
You can mount it anywhere between 12' 11" and 21' 1" from a 135" 16x9 screen. The zoom will adjust to fill the screen.New to projector here.
Using Epson projector calculator, using Epson 3800 on 135” screen, it recommends me to mount the projector about 157” away from the screen.
My question is if I mount it a bit closer or bit further away from the screen, does Epson 3800 have zoom where I can either zoom in or out to adjust? If it does, why the calculator is telling me to mount it at specific distance since you can use the zoom to adjust the size picture to fit the screen? Is the zoom effecting the quality of the picture?
Oh ok. There is no ideal sweet mount, yes? Zoom in or out will not degrade picture quality?You can mount it anywhere between 12' 11" and 21' 1" from a 135" 16x9 screen. The zoom will adjust to fill the screen.
It will be reasonably consistent through the zoom range.Oh ok. There is no ideal sweet mount, yes? Zoom in or out will not degrade picture quality?
if you listened and tried the projector central website all these questions you have is answered, throw distance, zooming in and out, and image brightness when zoomed in an outRight. But both calculators will still recommend me where to mount the projector. My original questions still unanswered though regardless which calculator I use.
