Hi just got a panny plasma with 15 pin vga in. Connected to dtc100 , signed up for hbo a la carte ect. I receive hd net ect using s video connection but when I switch no pc(hdtv) input I get the sign " no signal".
I tested the plasma monitor with a computer ..it worked , so the problem seems to be the dtc 100.It is an open box buy so can be returned.
Is there any thing I need to check or change to get the hdtv signal out of the vga??
Thanks for any help
thequietman
Thanks for any help
thequietman
