My new Panny 75u shows 525I signal from the Tosh sd9200. Going in to the Tosh menus I can select different parametrs for the interlaced signal such as brighness contrast etc. and see the change on the projected screen but when I select progressive and try to enter any changes or select anything I don't get any difference on the image and it seems to stay with the previous Interlaced options I chose. I am going component out to a cheap breakout cable red to red, blue to blue, green to green, black and grey breakout cables left dangling. I have not cut or jumped any pins on the connector to the pj. Any ideas? Am I doing something wrong or is there a problem with the Tosh.
I don't have any other HD or progressive display to check it on unfortunately.
thanks for any ideas -Noam
