1 - 4 of 4 Posts
I am going to connect the 4 wire in-wall cable (red, black green and white) with the wall plate, but I found only 2 wires can ben connected to the wall plate. What do I do with the other 2 wires? Just leave them unused? If I should use only 2 wires, do I use the red and black wires?
The fact that the wall plate has 2 jacks (red and black) is in conformity with my AV receiver that has 2 jacks (red and black) for Zone2 and 2 jacks (red and black) for Zone3. So a 2 RCA Plug / 2 RCA Plug M/M cable would connect both.
Any advice would be appreciated.
What's the wire for and what are you connecting to it? Is it speaker wire? Assuming so, the 4 wires would be for a pair of speakers - 2 wires per speaker. If you're looking at a receiver with Zone 2/3 outputs at line level (RCA jacks), you'll need an amplifier before hooking up to speakers...
Jeff
Uh? who? what? where?
OK, sounds like you are connecting 1 channel (2 wire per channel), then by all means leave the other 2 wires unused. How it got wired there with 4 wires only you know. If it's suppose to be stereo (2 wires per channel, 4 wire for stereo) then you have to ask yourself how come your plate has connectors for 1 channel only.
1 - 4 of 4 Posts
