That is because it is a powerful beast and way over-kill for a HTPC.
It is decent value for the money but HTPC's which (typically) run 24/7 or a majority of the time are low-powered.
The i7 880 is more than capable of the job.
However, if all you are going to use this setup for is a simple HTPC, you might be better off looking at a newer i3 or the AMD Fusion chips. These chips come with graphics on the same die and there is no need for a separate video or audio card (both via HDMI) for HTPC duties.
If you plan on gaming or using this machine for photo/video editing, then the i7 might be worth it.
