Status
Not open for further replies.
1 - 5 of 5 Posts
For some reason my UTV unit has stopped displaying the play, ff, 15x, bar graph and other related utv functions on the screen. Did I turn these off by accident, and how do I re-enable them?
I've tried rebooting the box, and it hasn't helped.
unplug it (you will lose the guide data though)
Putting your UTV in standby is not powering it off... standby is just a inactive state for output video and sound and clears buffers.
Pulling the plug forces a low level system test / reset (hardware) when you power up.
Sometimes you can achieve the same results by going to standby then press menu/options 12357
I had that problem early on when my UTV was enclosed in an entertainment center too tightly. make sure you have it well ventilated. Just a thought.
1 - 5 of 5 Posts
Status
