1 - 4 of 4 Posts
Im using moving pictures with DVD rips, Bluray Rips, and TV shows (recordered or ripped but want them all in 1 area ie tv shows)
Right now everything is coming up under 1 icon movies or videos i forgot which one off the top of my head
nothing shows up under blu ray or dvd, and the blu ray content isnt tagged hd or anything.
can someone offer some input on a folder and file structure for everything.
thanks
Could you rephrase?
Are you using MediaPortal?
If so:
Do you want to use Moving Pictures for your movies
Do you want to use TV Series plugin for TV-series?
MY folderstructure looks like this:
\\\\mediaserver\\media\\movies\\hd-filmer (720p/1080p mkv files)
\\\\mediaserver\\media\\movies\\hd-ISO (Complete BR-disks)
\\\\mediaserver\\media\\movies\\DVD-filmer (Complete DVD-disks)
\\\\mediaserver\\media\\movies\\DVD-rips (DVD rips mostly avi)
\\\\mediaserver\\media\ vSERIES\\showname\\showname- season xx\\showname - SxxExx - episodename
I then have Moving Pictures searching the 4 folders under \\\\mediaserver\\media\\movies\\ for movies
And TV series plugin searching the \\\\mediaserver\\media\ vseries\\ for TV-shows.
Discussion Starter · #3 ·
Yes im using media portal + moving pictures
Im starting to get it worked out, im having trouble with -
I want to be able to view random video clips, I put those into my videos folder, cant get em to show up.
And I cant get any HD content to be tagged HD like on the tumbnail view
my BR rips look the same as my DVD rips (as far as the thumbnail view goes)
edit i ripped the bluray with clown_bd and its in a .m2ts container
If you by random video clips mean video clips like "monkey sniffs his ass and falls down" and similar stugg then Moving Pictures won't pick those up as it's only meant to be for "real" movies. You'll have to use the MyVideos plugin that comes with MediaPortal for those.
As for marking your HD-movies with some sort of logo I think that'll be available in the 0.8 along with filtering.
1 - 4 of 4 Posts
