Status
Not open for further replies.
1 - 6 of 6 Posts
Greetings,
I am confused. Got off the phone with Direct TV and was told the 18" round dish was sufficient for receiving HD signals w/5.1 audio. I was told by a couple of other people I needed the Oval dish to receive HD w/5.1 audio. Which one is it? I want to be able to receive All current and future HD from Direct TV. Any help would be greatly appreciated. Will be getting the Panny TU-HDS20 Receiver.
Dom
You need the oval one, it allows you to look at two birds at once.
Brian
Current Set Up:
Pronto 2000
Sharp XV-DW100U LCD
Onkyo 575
RCA DTC 100
Zenith DVD
Inexpensive Pioneer Speakers
I was told by Direct TV that the 18 inch dish would work, but I would need a second 18 inch dish to get regular satelite programming. So it's easier to get the 24 inch instead of the two smaller ones.
Just "refresh", no need to add a post.
>I was told by Direct TV that the 18 inch dish would work, but I would >need a second 18 inch dish to get regular satelite programming. So it's >easier to get the 24 inch instead of the two smaller ones.
It MUST be the oval dish (or two round ones), not the 24" round dish available for fringe areas.
Brian
Current Set Up:
Pronto 2000
Sharp XV-DW100U LCD
Onkyo 575
RCA DTC 100
Zenith DVD
From my understanding there are 3 dishes:
the normal 18"
the bigger 24" (for better reception that 18")
the oval for looking at two sat's at once
HD is broadcast from the second DTV satellite (119) and you only need an 18" to look at that one sat. Most DTV programming is on sat 101, so to get both you need either two 18" dishes or one oval dish. One caveat about the oval: it is a compromise and will not get as much signal as having two round dishes pointed separately and it will be somewhat harder to aim if you install it yourself.
jake
1 - 6 of 6 Posts
Status
