Help! Panasonic TH-37PWD7UY stuck!!
483 Views 4 Replies 3 Participants Last post by  Techniwizard
Panasonic TH-37PWD7UY is stuck in standby mode. It will go to green light for a few seconds when first turn on, then goes to red and flashes 2 times and stays red then repeats flash. Any help appreciated.
Status
Not open for further replies.
1 - 5 of 5 Posts
Sounds like the power supply is shot.
John
Oh-oh! Worth fixing? Is it a DIY project? What is best option?
Medmike
Are you still under warentee? Don't tink I would try this DYI.
John
Medmike
Probably what is called the "SU" pcb. Repair $$$ is 2-3 hundred.
Check www.Panasonic.com under -support, find a servicer- and take it in for an estimate.
Probably NOT a panel defect so it is economical to fix.
NOT a DIY project, sorry. Parts are sold only to authorized dealers.
This is for YOUR protection to insure repairs only by trained and qualified techs.
Warranty is 1 yr parts and labor, you'll need your original invoice.
T Wiz
BTW, failures of this type are usually due to poor airflow/cooling when placed inside furniture enclosures or mounted in areas of poor airflow.
See less See more
1 - 5 of 5 Posts
Status
