Status
Not open for further replies.
1 - 2 of 2 Posts
HELP!!!:(
Does anyone know whether the Panasonic RP62 is incompatible with the Epson 71c projector.
Despite double checking all of the connections and setup parameters (ie. Aspect Ratio) I still have huge black bands seperating the picture. It will also alternate between rolling and appearing bottom over top in a split sceen. What in the world am I doing wrong? :confused:
I previously had it hooked up to a Phillips Progressive 724AT with no problems in picture, just issues with the DTS bug, which is why I switched.
Any feedback would be appreciated.
Banned
The only time one of my 4 DVD player split the screen into 2 seperate pictures was regional problem.
I would say your problem has to do with your connection, the disc has the regional info plus macrovison if it doesn't recognize your disc; it won't play right!
If you can't figure it out then make service call, I sincerely doubt there is anything wrong with calling a TV repairman
1 - 2 of 2 Posts
Status
