Status
Not open for further replies.
1 - 2 of 2 Posts
Hi Guys:
Less than 2 yr old 42 6UY Panny, wife turned it on today, and the entire right side has a green tint, starting just to the left of the Panasonic badge, top-bottom. The input setting is set to component, so its not that. The line is uniform, and the tint is apparent in every source and on all menu screens.
Any help for an anxious member?
thanx,
Joel
Discussion Starter · #2 ·
Note: This is not the overall "Green-push" that is uniform across the screen--
the left side of the screen is normal, it only has the green tint starting at the halfway point across the screen (vertical split) withleft side normal image, right side having that noticeable green push.
I appreciate any help/advice, I'm scrambling to find my receipt, I think I bought it from Visual Apex, I know it was a forum sponsor.
Cheers.
1 - 2 of 2 Posts
Status
