1 - 2 of 2 Posts
I recently upgraded my display to a Pioneer Kuro 60" (PDP-6010HD) and connected my XRGB-2plus via VGA connector only to find it has issues with syncing up the image (keeps jittering). Is that an unfixable issue? I also tried it via an Audio Authority VGA to component converter (9A60) to find it to be the same. Do I need to get an XRGB-3? The XRGB-2plus worked fine with my Sony rear projection LCD....
Would appreciate any advice. Tried taking a picture but it doesn't show up well.
1 - 2 of 2 Posts
