Originally Posted by
kday55 /forum/post/0
My husband and I are new to this whole game. We would like a 42-47" monitor for our family room. Low light, @10 foot viewing area. We already have a cable set up with Comcast, so don't need a tuner. Don't do games, like DVDS, NBC, ESPN, DISNEY, etc. WHat's the best bang for the buck, and even the best bang? I can't understand much of the hi- techie talk I've scanned thru, so please, guys, in laymans terms if possible! Thanks.(COLOR=Indigo)xxx(/COLOR)
First welcome.
I suggest narrowing the field so you can focus on a decision.
(1) Type: Given your use and that you have good lighting, I would strongly recommend you consider nothing but plasma. If you find for some reason that you are considering something else, from the dark side, come back and we can discuss this further.
(2) Size: Given your viewing distance, I would recommend absolutely nothing smaller than 50". 60" would be perfect at that distance for a "wide screen" experience but at the moment 60" comes at quite a price premium. 50" is the sweetspot as they say for plasma displays.
(3) Resolution: At that distance, you need not consider 1080p resolution, which is also limited at the present and very expensive. So 768p is fine and affordable. Again if you are tempted we can discuss this further. This is just a brief summary.
(4) Brands: There are a number of quality makers of plasma displays. Each is styled differently and so compatability with your home decor may or may not be important to you but that and the weight you give it is entirely a personal choice. You will also need to consider features such as a memory stick viewer for digital photo viewing that some displays have. Only you can weigh these for your family. As far as picture quality (PQ) goes, you will find many opinions here. Personally, I place NEC at the top followed closely by Pioneer Elite. Next I would put Pioneer and Panasonic with Samsung catching up with each generation.
While there are other brands, you should be able to find a display that suits your needs and makes you happy among these. There are extensive threads on each.
I would also encourage you to consider purchase from a forum sponsor either those at the top or the bottom of the plasma forum screen. Chris at Cleveland Plasma has a particularly good reputation for both price and service but give one of them a chance.
Should you go to stores to view displays, you should know that stores are often the worst environments in which to view but unfortunately we have no other. Just be sure to obtain the remotes and adjust the picture settings for a natural picture or any comparisons or judgements you make will be missleading and meaningless. There are any number of posts that address this. Certainly take them out of vivid or dynamic modes, adjust brightness for black (shadow) detail and contrast for white level, and moderate the color hue or saturation to obtain as natural a picture including skin tone as you can.
Also make sure you view at the distance you expect to have at home and never view out in the middle of a store having bright, harsh lighting.
Let us know what you observe and any more specific questions that then come to mind.
Good luck and enjoy the hunt. It can be fun. Hope you find it so.
Cheers,
Gary
