I have a Blu-ray writer which I use to watch Blu-ray films on my TV using PowerDVD Ultra which works fine.
I have an XBox 360 HD-DVD drive connected with drivers (so I can see the files on the discs), I want to use WinDVD HD version to watch HD-DVD movies, I can load up the software fine, but when I put in an HD-DVD disc it brings up a black box (takes up 3/4 of my screen), it's not windowed (no title bar etc), it flashes multi-coloured (sometimes the whole thing changes coloour, sometimes it's made up of loads of different coloured squares) then it dissapears, all in under a second
now, another thing I've noticed is that the WinDVD codecs seem to crash Windows Media Player if I play h.264 files from my HDD and the HD-DVD I have (like most of them) is encoded in h.264, so I have a utility that can set priority of codecs and I've dropped the WinDVD ones right down so Windows Media Player uses the PowerDVD codecs which work fine.
I've re-installed Windows and tried again but the codecs still don't work
does anyone have any ideas?
thanks in advance for any help/ideas
