Status
Not open for further replies.
1 - 9 of 9 Posts
Hi to all,
Currently, I am considering this projector but I have not found answers for these questions yet...
-Is the throw distance of the 12HT the same than the 11HT?
-Are the 12HT and the 11HT "exactly" the same estetically?
-Exists any difference about screendoor between these two projectors?
-Works the DRC technology from Pal sources?
-Is the MicroLensArray feature included on both projectors?
-Has the 12HT any input or connection that 11HT lacks?
Could anyone help me about, please?
Thanks a lot!
Josu,
I've got pdf's (From the net, but look like the genuine article) for both and they can answer a few of your queries. I was asking the same when thinking of upgrading my poorly VW10HT for a VW12HT.
The throw distances for the VW10HT, 11HT & 12HT are all the same.
The dimensions are also identical as is the weight.
Screendoor is not an issue. I sit about 11 - 12 feet back from a 106' 16x9 screen and can see no screendoor on the VW10HT. I'd guess that this would only be improved on the 11 & 12.
Both have the same connection panel in the same position.
Basically all three machines are identical, just improvements on the inside.
Let me know if you would like both pdf's
Cheers
Hugh
Discussion Starter · #3 ·
Thanks a lot Hugh!
I would be very interesed about those pdfs...
Did you upgraded finally for the 12HT? Are much difference about image quality between the 10HT and the 12HT? If not I would consider the HS10 because I have heard that it is similar to the currently not available 10HT.
Best regards!
I haven't upgraded yet. I'm hoping I won't need to. My VW10HT might be rescued. I've a thread going on a forum asking for factory settings which should hopefully sort my projector out.
Send me a private message with your email address and I'll send you the pdf's.
Hugh
josu,
-Exists any difference about screen-door between these two projectors?
Yes. The screen door effect is less apparent in 12HT compared to that of 11HT.
No. Only 12HT has the MLA
No. However, 12HT supports 525P.
12HT has also better blacks, better contrast and needs few adjustment compared to its previous models.
Discussion Starter · #6 ·
Thanks for the information, Joaquin!
Hugh, you have a PM.
JVC NZ8, 2.35:1 125" screen, Marantz AV7705, 7.2.4 Def Tech speakers, Sunfire Theater Grand 400x7
I'd rank the HS10 above the 11HT at this point, with the 12HT having better CR and MLA over the HS10, but no DVI and more money. Suggest skipping the 11HT.
Have you considered the NEC HT1000? Have to ask because its that good.....
Discussion Starter · #8 ·
Thanks Steve!
I am considering the 12HT because of its recent price drop here in Europe.
Discussion Starter · #9 ·
Thanks Hugh,
I have received the pdfs. Are very helpfull.
Thanks a lot for the support!
See you!:)
1 - 9 of 9 Posts
Status
