1 - 7 of 7 Posts
Hi,
I have a 5080 that has worked perfectly until yesterday, when I lost the guide completely. The guide still shows the channels, but there's no program info at all. I tried reconnecting via the menu and via 243 Zones, but same result. The RTV appears to connect to the server and goes through the usual steps, with the completion percentages appearing on the screen, but when it's done there's still no program info at all in the guide.
Any thoughts on how to fix?
Bill
Clear the guide 3 times then do a net connect.
If that fails then try a factory reset. I believe that's 386-zones, but I'm not 100% sure and I'm too lazy to look it up. BTW, factory reset gets rid of all your recorded shows.
Thanks! I'll give these a try.
1 - 7 of 7 Posts
