1 - 5 of 5 Posts
Hi Guys,
I have spent over couple hours trying to figure how to have auto audessy speaker set up run with only 5.1 set up. But, I can't get the reciever to turn surround speakers off with out turning rear surround off too! So my questions are:
Does auto audessy setup works with 5.1 setup?
How do I tell the reciever there are no surround speakers?
All help and input greatly apprecaited!
i have try'd running the set-up and get the same error everytime...
I have kef 2005.2 speakers and the onkyo 605...
It goes through the automatic set-up.... til it reaches the right back speaker...
then brings up an error flashing both SR : no and SBR : Yes...
it doesn't bother looking for the SBL or SL, just stops at this stage...
I can get sound out of all the speakers... but i don't seem to be able to run the set up through? nothing is blocking either the onkyo or the speakers...
any help or thoughts....
Originally Posted by iamitman /forum/post/13068479
Thanks Kal.. I figured it out that day by reading top 10 mistake post! Also, does it make any difference having your rears plugged as surrounds.
Isn't that what we just discussed?
1 - 5 of 5 Posts
