Status
Not open for further replies.
1 - 2 of 2 Posts
I just ordered a Dish Network reciever the 811 and am getting ready to move into HD. Problem is I have a Sony 1252 projector with only BNC inputs on it. I currently use a DVDO Iscan doubler to convert my Svideo and composite signals for use on the projector. With the 811 HD reciever the outputs are component and DVI-D any suggestions on how I can connect the receiver to my projector? Any help would be greatly appreciated
sdd110
Get a transcoder. I suspect the DVDO doesn't have component inputs?
A transcoder will convert the component signal to RGBHV so you can connect to your projector. Unless you have another input on your projector, you might want to find a transcoder that as a passthrough so you can pass the DVDO though it. Or perhaps the DVDO has a RGBHV passthrough which you can connect the transcoder to.
Cheap transcoders can be had for around $200. Check ebay too.
1 - 2 of 2 Posts
Status
