Status
Not open for further replies.
1 - 2 of 2 Posts
I'm not sure if this is the right place to post this, But I have issues with my Linksys router and Streaming audio!
I have windows Media Encoder that I used to encode a Scanner feed i have put into my computer, I have a Linksys WRT54G Router.
Anyone know where to find a "Step by step" way to configure my router so it provides a way for ppl to connect to my router to listen to this feed??
That or if anyone has time to walk me through this. It be so much help!
Again, Sry if this is posted in the wrong topic, Wasn't to sure as to where this would fit!
Shawn
Find out what "ports" (UDP/TCP/HTTP) it uses for the stream and allow/pass them in the router configuration.
Note that by doing so, you compromise the firewall/security of your PC.
The manual can be helpful and you can also place a call to "Linksys" support.
1 - 2 of 2 Posts
Status
