1 - 3 of 3 Posts
· Registered
I bought the samsung hd860 upconverter dvd player along with hdmi cable. I have a samsung tx3079 30 inch slim fit hdtv. I attempted to hook up the dvd player correctly with hdmi cable but when i switch input source on tv to hdmi and try to use dvd player it says no signal. I returned both dvd player and cable thinking it was that but the new ones do the same. Please help!
· Registered
Did you go into the dvd players menu to output via hdmi,and I think you need to also set the tv to hdmi as well.
1 - 3 of 3 Posts
