Status
Not open for further replies.
1 - 3 of 3 Posts
Hi,
For the last few days I notice faint vertical lines all across the screen. The lines are visible during high contrast scenes.
The strange thing is that the lines appear only when the DVD is in progressive mode. They are not to be found during interlace mode or any other source.
Any ideas of solving this annoying problem will be greatly appreciated
Ran
Does the Sony have something in the service menu called "Eight Bar Drivers" or something like that? Just a shot in the dark, but a similar artifact can be found on some other projectors if the "Eight Bar Drivers" are not set correctly.
Sorry I can't help more, but I thought I'd throw this out there to see if it can give you a direction. I know how frustrating it can be to have an issue that no one has an opinion on.
Discussion Starter · #3 ·
Thank you for your quick reply.
To my best of knowledge there is no "Eight Bar Drivers" in the Sony's service/factory menu.
As you can imagine this is very frustrating since I have to use the Toshiba in it's interlace mode.
Someone????
Ran
1 - 3 of 3 Posts
Status
