I guess you mean you are using the computer monitor cable for the XB-31 and not the DVI cable.
Did you try hitting the source button on the XB-31 remote to get it to try to find another format?
If that fails, try using a s-video connection (yeah, I know) as an experiment for the regular channels.
BTW, I downloaded the DTC-100 manual and it reads like an idiot's guide; no technical info at all.
